Adds an entry to the MAC address list for MAC-based network login.
| mac | Specifies the MAC address to add. |
| mask | Specifies the number of bits to use for the mask. |
| default | Specifies the default entry. |
| encrypted | Used to display encrypted form of password in configuration files. Do not use. |
| password | Specifies the password to send for authentication. |
| ports | Specifies the port or port list to use for authentication. |
If no password is specified, the MAC address will be used.
Use this command to add an entry to the MAC address list used for MAC-based network login.
If no match is found in the table of MAC entries, and a default entry exists, the default will be used to authenticate the client. All entries in the list are automatically sorted in longest prefix order.
configure netlogin add mac-list default configuration is added by default when enable netlogin mac is configured.
You can configure the switch to accept and authenticate a client with a specific MAC address. Only MAC addresses that have a match for the specific ports are sent for authentication. For example, if you associate a MAC address with one or more ports, only authentication requests for that MAC addresses received on the port(s) are sent to the RADIUS server. The port(s) block all other authentication requests that do not have a matching entry. This is also known as secure MAC.
To associate a MAC address with one or more ports, specify the ports option when using the configure netlogin add mac-list [mac {mask} | default] {encrypted} {password} {portsport_list} command.
You must enable MAC-based network login on the switch and the specified ports before using this command. If MAC-based network login is not enabled on the specified port(s), the switch displays a warning message similar to the following:
WARNING: Not all specified ports have MAC-Based NetLogin enabled.
If this occurs, make sure to enable MAC-based network login.
The following command adds the MAC address 10:20:30:40:50:60 with the password foo to the list:
configure netlogin add mac-list 10:20:30:40:50:60 password foo
The following command associates MAC address 10:20:30:40:50:70 with ports 2:2 and 2:3. This means authentication requests from MAC address 10:20:30:40:50:70 are only accepted on ports 2:2 and 2:3:
configure netlogin add mac-list mac 10:20:30:40:50:70 ports 2:2-2:3
This command was first available in ExtremeXOS 11.1.
The ports option was added in ExtremeXOS 11.3.
Default configuration when enable netlogin mac is entered was added in ExtremeXOS 31.3.
This command is available on all Universal switches supported in this document..
