Configure the ports that will be hijacked and redirected for HTTP or HTTPS traffic.
| tcp_port | Specifies the port to be hijacked. |
HTTP traffic.
This command allows you to configure the ports that will be hijacked and redirected for HTTP or HTTPS traffic. For each hijacked proxy port, you must specify whether the port is to be used for HTTP or HTTPS traffic.
No more than 5 such ports are supported in addition to ports 80 and ports 443. Attempts to add more than 5 ports generate an error.
