Removes a list of ports from the VR specified.
| vr-name | Specifies the name of the VR. |
| port_list | Specifies the ports to remove from the VR. |
By default, all ports are assigned to VR-Default.
When a new VR is created, by default, no ports are assigned, no VLAN interface is created, and no support for any routing protocols is added. Use this command to remove ports from a VR. Since all ports are initially assigned to VR-Default, you might need to delete the desired ports first from the VR where they reside before you add them to the desired VR.
The following example removes all the ports on slot 2 from the VR "vr-acme":
configure vr vr-acme delete ports 2:*
This command was first available in ExtremeXOS 11.0.
