Starts a Layer 3 protocol instance for a VR or VRF.
| vr_name | Specifies the name of a VR or a VRF. |
| protocol | Specifies a Layer 3 protocol that you can add or delete. |
name |
Specifies the name of a VR or a VRF. The following protocols are supported on VRs: RIP, RIPng, OSPF, OSPFv3, BGP, PIM. IS-IS, and MPLS. The following protocols are supported on VRFs: BGP, OSPFv3. |
| add | Adds a routing protocol to VRF for PE – CE communication . |
| delete | Specifies the name of a VR or a VRF. |
By default, none of the dynamic protocols are added to a User VR or a VRF.
When a new VR or VRF is created, by default, no ports are assigned, no VLAN interface is created, and no support for any routing protocols is added.
MPLS is the only protocol that you can add to or delete from VR-Default. When MPLS is enabled on a switch, the default configuration adds MPLS to VR-Default. You cannot add or delete any other protocols from VR-Default, and you cannot add or delete any protocols from the other system VRs, VR-Mgmt and VR-Control.
You must delete the MPLS protocol from VR-Default before you can add it to a user VR. MPLS can be active on only one VR within a switch.
OSPFv3 protocol can be added only to the user VR and non-VPN VRF.If a previously configured protocol instance is deleted, the CE routes imported from that protocol into the VRF RIB is removed.
The following example starts RIP on the VR "vr-acme":
configure vr vr-acme add protocol rip
The following example starts a BGP protocol instance for VRF "vr-widget":
configure vr vr-widget add protocol bgp
This command was first available in ExtremeXOS 11.0.
MPLS protocol support was added in ExtremeXOS 12.4.
Support for the OSPFv3 and RIPng protocols on user VRs was added in ExtremeXOS 12.5.
Support for the BGP protocol on VRFs was added in ExtremeXOS 12.6.0-BGP.
This command is available on ExtremeSwitching 5420, 5520, 5720 series switches.
