Creates a storage file for DHCP binding information.
| name | Specifies the name of the DHCP binding storage file. |
N/A.
This commands allows you to configure the filename with which the DHCP bindings storage file is created on the external server when it is uploaded to the external server. The text file resides on an external server. You can configure the server with the command configure ip-security dhcp-bindings storage location server [primary | secondary] ip_address | hostname]{vrvr-name} tftp.
The bindings file must have a .xsf extension. If the input filename doesn't already have a .xsf extension, one is added automatically.
