Deletes a DHCP binding.
| ip_address | Specifies the IP address for the DHCP binding. |
| vlan_name | Specifies the name of the VLAN for the DHCP binding. |
| dynamic | Configuration options for dynamically created VLANs. |
| vlan_id | VLAN ID tag between 1 and 4,094. |
N/A.
This commands allows you to delete a DHCP binding created with the command configure ip-security dhcp-binding add ip ip_address mac mac_address {vlan}vlan_name server-portserver_port client-portclient_port lease-timeseconds.
Dynamic VLAN and VLAN ID options added in ExtremeXOS 30.2.
