show cfm segment
show cfm segment {segment_name}
Description
Displays information for CFM segments.
Syntax Description
segment_name
An alpha numeric string identifying the segment name.
Default
N/A.
Usage Guidelines
Use this command to display information for the selected CFM segment.
If a segment name is not specified, the information for all of the segments that are currently configured are displayed.
The following command displays information for an active CFM segment that is configured to transmit with a specific count:
show cfm segment s2
CFM Segment Name                : s2
Domain Name                     : pbt-d2
Association                     : pbt-d2-protecting
MD Level                        : 2
Destination MAC                 : 00:04:96:1e:14:70
DMM Transmission                : In Progress
Transmission mode               : Continuous
Frames Transmitted              : 2
Frames Received                 : 2
DMM TX Interval                 : 2secs
DMR RX Timeout                  : 10 msec
Alarm Threshold                 : 10 %
Clear Threshold                 : 95 %
Measurement Window Size         : 60
Class of Service                : 0
Tx Start Time                   : Sun Apr 19 21:18:58 2009
Min Delay                       : Sun Apr 19 21:18:58 2009
Max Delay                       : Sun Apr 19 21:19:00 2009
Last Alarm Time                 : None
Alarm State                     : Not Set
Lost Frames in Current window   : 0
Total Configured Segments       : 2
Total Active Segments           : 1
The following command displays information for a disabled segment:
BD-12804.1 # sh cfm seg s2
MD Level                        : 2
DMM Transmission                : Disabled
Frames Transmitted              : 10
Frames Received                 : 10
Tx Start Time                   : Sat Apr 18 05:39:54 2000
Min Delay                       : Sat Apr 18 05:40:12 2000
Max Delay                       : Sat Apr 18 05:39:56 2000
Lost Frames in Current window   : 1
Total Active Segments           : 0
This command was first available in ExtremeXOS 12.3.
Platform Availability
