This command displays frame-delay information for the given CFM segment – MEP ID combination.
segment_name |
An alpha numeric string identifying the segment name. |
N/A.
Use this command to display frame-delay information for the given CFM segment – MEP ID combination.
Switch#showcfm segment sc-rtp
CFM Segment Name : sc-rtp
Domain Name : pbt-d2
Association : pbt-d2-protectingMD
Level : 2
Destination MAC : 00:04:96:1e:14:70
Frame Delay:
MEP ID : 100
__________________________________________________________
DMM Transmission : In Progress
Transmission mode : Continuous
Frames Transmitted : 24
Frames Received : 15
DMM Tx Interval : 2 secs
DMR Rx Timeout : 10 msec
Alarm Threshold : 10 %
Clear Threshold : 95 %
Measurement Window Size : 60
Class of Service : 0
Tx Start Time : Fri Apr 17 01:29:45 2009
Min Delay : Fri Apr 17 01:30:29 2009
Max Delay : Fri Apr 17 01:30:03 2009
Last Alarm Time : Fri Apr 17 01:29:59 2009
Alarm State : Set
Lost Frames in Current Window : 9
MEP ID : 200
Alarm State : Set
Frame Loss:
LMM Tx Interval : 2 secs
LMR Rx Timeout : 10 msec
SES Threshold : 30 %
Consecutive Available Count : 10
Total Configured MEPs : 2
Total Active MEPs : 2
MEP ID : 100
LMM Transmission : In Progress
Availability Status : Available/Unavailable
Unavailability Start Time : Fri Apr 17 01:10:45 2011
Unavailability End Time : Fri Apr 17 01:20:45 2011 Tx
Start Time : Fri Apr 17 01:10:45 2011 Min
Near-End Frame Loss : Fri Apr 17 01:29:45 2009 Max
Near-End Frame Loss : Fri Apr 17 01:39:45 2009 Min
Far-End Frame Loss : Fri Apr 17 01:49:45 2009 Max
Far-End Frame Loss : Fri Apr 17 01:59:45 2009
MEP ID : 200
Tx Start Time : Fri Apr 17 01:10:45 2011
Min Near-End Frame Loss : Fri Apr 17 01:29:45 2009
Max Near-End Frame Loss : Fri Apr 17 01:39:45 2009
Min Far-End Frame Loss : Fri Apr 17 01:49:45 2009
Max Far-End Frame Loss : Fri Apr 17 01:59:45 2009
Total Configured Segments : 1
Total Active Segments : 1
This command was first available in ExtremeXOS 15.4.
