Disables the BOOTP relay function on one or all VLANs for the specified VR or VRF.
| vlan_name | Specifies a single VLAN on which to disable the BOOTP relay feature. |
| vr_name | Specifies a single VR on which to disable the BOOTP relay feature. |
| all | Specifies that BOOTP relay is to be disabled for all VLANs on the specified VR or VRF. |
The BOOTP relay function is disabled on all VLANs and VRs.
Because VLAN names are unique on the switch, you can specify only a VLAN name (and omit the VR name) to disable BOOTP relay. When you disable BOOTP relay on a VR or VRF, BOOTP relay is disabled on all VLANs for that VR. If you enter the command without specifying a VLAN or a VR, the functionality is disabled for all VLANs in the current VR context.
The following command disables the forwarding of BOOTP requests on all VLANs in the current VR context:
disable bootprelay
You can use either of the following commands to disable the forwarding of BOOTP requests on VLAN unit2:
disable bootprelay unit2 disable bootprelay vlan unit2
You can use any one of the following commands to disable the forwarding of BOOTP requests on all VLANs in VR zone3:
disable bootprelay zone3 disable bootprelay vr zone3 disable bootprelay all zone3 disable bootprelay all vr zone3
The capability to disable BOOTP relay on a VLAN was added in ExtremeXOS 12.4.2.
