Disables CDP on a port.
| port_list | Specifies the list of ports to disable CDP on. |
| all | Specifies that you disable CDP on all ports. |
Enabled.
The following command disables CDP on all ports on the switch:
disable cdp ports all
This command was first available in ExtremeXOS 15.4.
