Configures the VLAN for Network Login.
| vlan | Specifies the VLAN for Network Login. |
N/A.
This command will configure the VLAN used for unauthenticated clients. One VLAN needs to be configured per VR. To change the VLAN, network login needs to be disabled. Network login can only be enabled when a VLAN is assigned (and no ports are configured for it).
By default no VLAN is assigned for network login.
The following command configures the VLAN login as the network login VLAN:
configure netlogin vlan login
This command was first available in ExtremeXOS 11.1.
