Use this command to set the NetLogin system traps.
| enable | Enable sending traps when max users reached in system |
| disable | Disable sending traps when max users reached in system |
Disabled.
The specifications from this command appear in show configuration {module-name} {detail} for "policy" and "netlogin."
This example shows how to enable the NetLogin maximum users trap setting:
configure netlogin trap max-users enabled
This command was first available in ExtremeXOS 16.1.
