Configures an OID to perform a hierarchical search if the LDAP server requires it.
| domain_name | Domain name on which to configure ldap. |
| all | All domains. |
| ldap-matching-rule-in-chain | Configures the OID 1.2.840.113556.1.4.1941. |
| oid | Object identifier. |
| none | Specifies that LDAP query should not include any OID for hierarchical search. |
N/A.
Use this command to configure an OID to perform a hierarchical search if the LDAP requires it. The OID supplied with this command will be used to form the LDAP query. If a server does not require extended control OID, the none option can be selected.
configure ldap domain abc.com hierarchical-search-oid ldap_matching_rule_in_chain
This command was first available in ExtremeXOS 15.3.
