Enables or disables LDAP queries for the specified type of network login users.
| domain_name |
Specifies the LDAP doman for which this configuraton is to be applied. |
| dot1x |
Enables or disables LDAP queries for dot1x network login. |
| mac |
Enables or disables LDAP queries for MAC network login. |
| web-based |
Enables or disables LDAP queries for web-based network login. |
LDAP queries are enabled for all types of network login.
It may be necessary to disable LDAP queries for specific type of netlogin user, for example, netlogin mac users, whose username is the same as mac address. The LDAP directory might not contain useful information about these type of users and unnecessary LDAP queries can be avoided.
LDAP queries are not sent for locally authenticated network login users.
The following command enables LDAP queries for MAC network login:
* Switch.99 # configure ldap enable netlogin mac
The following command disables LDAP queries for dot1x network login:
* Switch.99 # configure ldap disable netlogin dot1x
This command was first available in ExtremeXOS 12.5.
