Use this command to turn off SNMP trap support for L3 VPN.
| vr_name | Specifies the name of the parent VR where this RFC 4382 scalar is applied. If vr_name is not provided, then this command is applied to the VR in the current context. |
Enabled.
Use this command to disable L3VPN SNMP traps.
The following example disables L3 VPN SNMP traps support on the switch:
disable snmp traps l3vpn vr vr-default
This command was first available in ExtremeXOS 15.3.
