Disables SNMP traps associated with Layer 2 VPNs for all MPLS configured VLANs.
All Layer 2 VPN traps are disabled.
The following command disables SNMP traps associated with Layer 2 VPNs:
disable snmp traps l2vpn
This command was first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
