Displays statistics of anomaly violation events in real time.
| port_list |
Specifies one or more ports or slots and ports. |
tag |
Specifies an 802.1Q or 802.1ad tag value. |
no-refresh |
Specifies a static snapshot of data. |
| refresh | Continous refresh of output. |
N/A.
If you do not specify a port number, range of ports, or tag value, statistics are displayed for all ports. To clear the counters, use the clear counters ports command. The default display is a constantly refreshing real-time display. If you specify the no-refresh parameter, the system displays a snapshot of the data at the time you issue the command.
This command takes effect after enabling anomaly-protection.
The tag value may be associated with either a VMAN or a VLAN.
The following command displays real-time anomaly statistics on a switch:
show ports anomaly
Following is sample output from this command:
Port Statistics Thu Nov 9 22:44:31 2006 Port Link Rx Pkt ============ Anomaly Violation ========= State Count L3 Count L4 Count ICMP Count Frag Count ================================================================================ 1 A 191585 1 2 0 0 2 R 0 0 0 0 0 3 R 0 0 0 0 0 4 R 0 0 0 0 0 5 R 0 0 0 0 0 6 R 0 0 0 0 0 7 R 0 0 0 0 0 8 R 0 0 0 0 0 9 R 0 0 0 0 0 10 R 0 0 0 0 0 11 R 0 0 0 0 0 12 A 178024 0 0 0 0 13 A 196956 0 0 0 0 14 R 0 0 0 0 0 15 R 0 0 0 0 0 16 R 0 0 0 0 0 17 R 0 0 0 0 0 ================================================================================ Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback 0->Clear Counters U->page up D->page down ESC->exit
This command was first available in ExtremeXOS 12.0.
The tag value was added in ExtremeXOS 12.4.4.
The refresh keyword was added in ExtremeXOS 16.1.
