show ports auto 1G-optics-in-10G-ports
Description
Displays the default 1Gbps auto-negotiation mode for 10 Gbps ports when 1 Gbps optics are inserted in the port.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
Use this command to display the default 1 Gbps auto-negotiation mode for 10 Gbps ports when 1 Gbps optics are inserted in the port.
The following command displays the default 1 Gbps auto-negotiation mode for 10 Gbps ports when 1 Gbps optics are inserted in the port:
Auto negotiation for 1G optics in 10G ports    : Off
This command was first available in ExtremeXOS 32.7.1.
Platform Availability
