Displays RIP-specific configuration and statistics for all VLANs.
| detail |
Specifies detailed display. |
Show summary output for all interfaces.
The following command displays the RIP configuration for all VLANS:
# show rip interface
The following is sample output from this command:
# show rip interface VLAN IP Address Flags Sent Rcvd Triggered Cost Packets Packets Updates Flags: (f) Interface Forwarding Enabled, (i) Interface RIP Enabled (n) Multinetted VLAN, (r) Router RIP Enabled
The following command displays RIP-specific statistics for all VLANs:
# show rip interface detail
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
