Displays RIP specific memory usage.
| detail |
Displays detail information. |
| memoryType |
Specifies the memory type usage to display. |
N/A.
None.
The following command displays RIP specific memory for TEST:
# show rip memory test
The following is sample output from this command:
# show rip memory test RIP Memory Information ---------------------- Bytes Allocated: 0 AllocFailed: 0 Current Memory Utilization Level: GREEN Memory Utilization Statistics ----------------------------- Memory Statistics for TEST -------------------------------- Size 64 80 96 256 384 512 768 1024 2048 40 96 18432 --------- ------ ------ ------ ------ ------ ------ ------ ------ ------ ---- -- ------ Alloced 0 0 0 0 0 0 0 0 0 0 0 AllocedPeak 0 0 0 0 0 0 0 0 0 0 0 AllocSuccess 0 0 0 0 0 0 0 0 0 0 0 FreeSuccess 0 0 0 0 0 0 0 0 0 0 0 AllocFail 0 0 0 0 0 0 0 0 0 0 0 FreeFail 0 0 0 0 0 0 0 0 0 0 0
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
