This command is provided for backward compatibility. The recommended command is:
show mcast cache {{vlan} name} {{[group grpaddressMask | grpaddressMask] {source sourceIP | sourceIP}} {type [snooping | pim | mvr]}| {summary}}The syntax for the original form of this command is:
show igmp snooping cache {{vlan} name} {{group} grpaddressMask}Displays multicast cache entries added by IGMP snooping for all VLANs and groups. The display can be limited to specific VLANs or groups.
| name | Specifies a VLAN name. |
| grpaddressMask | Specifies a multicast group address and mask. |
Displays information for all VLANs and groups.
None.
The following command displays IGMP snooping cache information for all VLANs and groups:
This command display is the same as for the following preferred command:
show mcast cache {{vlan} name} {{[group grpaddressMask |grpaddressMask] {source sourceIP |sourceIP}} {type [snooping | pim | mvr]}| {summary}}This command was first available in ExtremeXOS 10.1.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
