Lists the IGMP group membership for the specified VLAN.
name | Specifies a VLAN name. |
grpipaddress | Specifies a group IP address. |
IGMPv3 | Displays the IGMP group in IGMPv3 format (if group record is IGMPv3 compatible, otherwise displays in earlier format). |
IGMPv2.
If no VLAN is specified, all VLANs are displayed. You can also filter the display by group address or by multicast stream sender address.
The output of this command shows:
The show igmp group command output is populated on the router that is the PIM Rendezvous Point.The following is sample output from the show igmp group command, listing the IGMP group membership:
Group Address Ver Vlan Port Age 239.2.4.70 2 banana 7 101 224.0.1.24 2 banana 7 107 239.255.255.254 2 banana 7 103 Total: 3
The IGMPv3 option was added in ExtremeXOS 11.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
