Configures the route timeout period.
| seconds |
Specifies a time in seconds. |
180 seconds.
If a router does not receive an update message from its neighbor within the route timeout period (180 seconds by default), the router assumes the connection between it and its neighbor is no longer available.
The following example sets the route timeout period to 120 seconds:
# configure rip routetimeout 120
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
