Configures the import policy for RIP.
| policy-name | Specifies the policy. |
No policy.
An import policy is used to modify route attributes while adding RIP routes to the IP route table. The import policy cannot be used to determine the routes to be added to the routing table.
Use the none option to remove an import policy.
The following example applies the policy campuseast to RIP routes:
# configure rip import-policy campuseast
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
