Configures the either the virtual router or the IP address for the Cloud Connector to use.
| vr | Specifies the virtual router for Cloud Connector to use.. |
| vr_name | Specifies the virtual router name. |
| ipaddress | Specifies the on-premises network management server IP address, which overrides the DNS resolved IP address. |
| ip_address | Specifies the on-premises network management server IP address. |
| none | Specifies the use of the auto-discovered information from auto-provision discovery. |
N/A.
This command allows you to troubleshoot the Instant Port profile installed.
The following example configures VR-Mgmt as the virtual router for Cloud Connector.
configure auto-provision cloud-connector server vr VR-Mgmt
The following example configures the on-premises network management server IP address as 10.139.12.70 for Cloud Connector.
configure auto-provision cloud-connector server ipaddress 10.139.12.70
This command was first available in version 32.7.1.
