Connects or disconnects an Automation Edge remote VXLAN network identifier (VNI)-device database.
| automation | Designates configuring Automation Edge VXLAN VNI-device database information. |
| edge | Designates configuring Automation Edge VXLAN VNI-device database information. |
| connect | Designates connecting to the specified database. |
| disconnect | Designates disconnecting from the specified database. |
| database | Designates connecting or disconnecting a database. |
| database_name | Sets the database name that you are connecting or disconnecting. |
N/A.
To connect to another new database, an existing database must be disconnected first. To view the connected database, use the command show database database_name
The following example connects the database "database1":
# configure automation edge connect database database1
The following example disconnects the database "database1":
# configure automation edge disconnect database database1
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
