Enables or disables the sending of a syslog message for MAC lock messages.
| port_list | Specifies one or more ports or slots and ports. |
| violation | Sends a syslog message if the maximum value configured for dynamic and static MAC locking is exceeded. |
| threshold | Sends a syslog message if the maximum value configured for dynamic and static MAC locking is reached. |
| on | Sending a syslog message for the specified event is enabled. |
| off | Sending a syslog message for the specified event is disabled. |
If neither violation nor threshold is specified, violation is used by default.
When MAC locking violations are enabled, the device sends a syslog message if a connected end station exceeds the maximum value configured for dynamic and static MAC locking.
When MAC locking thresholds are enabled, the device sends an syslog message if a connected end station reaches the maximum value configured for dynamic and static MAC locking.
The following example enables threshold syslog messages on port 14.
configure mac-locking ports 14 log threshold on
This command was first available in ExtremeXOS 15.7.1.
