Configures a port to be disabled or remain enabled when the port learns the configured maximum number of MACs.
| port_list | Specifies one or more ports or slots and ports. |
| disable-port | Disables the port when the configured MAC limit is reached. |
| remain-enabled | Port remains enabled after the configured MAC limit is reached. |
The port remains enabled after the configured MAC limit is reached.
This command is used for both first arrival and static MAC locking methods.
The following example configures port 14 to be disabled when the configured MAC limit is reached.
configure mac-locking ports 14 learn-limit-action disable-port
This command was first available in ExtremeXOS 15.7.1.
