show switch mounts
show switch mounts
Description
Displays whether a USB 2.0 storage device is present on the switch.
Syntax Description
Default
N/A.
Usage Guidelines
None.
This command shows whether a removable USB storage device is present on the switch:
# show switch mounts
The following output appears.
If you do not have a removable storage device installed:
Memory storage is not present.
If only one USB is supported and present:
Memory storage is present.
When two USBs are supported and present:
Memory storage is present in USB-1.
Memory storage is present in USB-2.
This command was first available in ExtremeXOS 11.0.
Support for USB 2.0 storage devices was added in ExtremeXOS 12.5.3.
The memorycard keyword was deprecated and replaced with the keyword mounts in ExtremeXOS 30.7.
Platform Availability
