show switch usb
show switch usb
Description
Shows the status (enabled or disabled) of the switch's USB port.
Syntax Description
usb Specifies USB port on switch.
Default
N/A.
Usage Guidelines
The enable/disable switch usb commands require a reboot to take effect. This is reflected in the output of this show command:
# show switch usb
USB port: Enabled
# disable switch usb
This setting will take effect at the next system reboot.
# show switch usb
USB port: Enabled (Disabled after the next reboot)Or in the same output, you can add:"After disabling usb using 'disable switch usb' output will be like this:# show switch usbUSB port: Enabled (Disabled after the next reboot)
The following example shows the switch's USB port status:
# show switch usb
USB port: Enabled
This command was first available in ExtremeXOS 22.3.
Platform Availability
