Displays general loading sharing information.
| port | View load sharing information for a specific port. |
| port_number | View load sharing information for a specific port. |
| detail | Show details for the specified ports in the load sharing group. |
N/A.
The following example shows load sharing information for the switch:
# show sharing
show sharing
Load Sharing Monitor
Config Current Agg Min Ld Share Dist Ld Share Agg Link Link Up
Master Master Control Active Algorithm Flags Group Mbr State Transitions
1:91 1:91 Static 1 L3_L4 A 1:91 Y A 1
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Minimum Active: (<) Group is down. # active links less than configured minimum
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
(L3_L4) Layer 3 address and Layer 4 port based
(custom) User-selected address-based configuration
Custom Algorithm Configuration: ipv4 L3-and-L4, xor
Custom Hash Seed: Switch MAC address (0x969C3CE2)
Distribution Flags:
A - All: Distribute to all members,
L - Local Slot: Distribute to members local to ingress slot,
P - Port Lists: Distribute to per-slot configurable subset of members,
R - Resilient Hashing enabled.
Number of load sharing trunks: 1
This command was first available in ExtremeXOS 11.0.
Custom hash seed information was added in ExtremeXOS 30.1.
