Displays the load sharing distribution to member ports in the group specified by port for traffic received on ports in port_list.
ports |
Specifies the group of member ports to display for the load sharing. |
port_list |
Specifies the group of ports from which traffic is received. |
N/A.
Use this command to display the load sharing distribution to member ports in the group specified by port for traffic received on ports in port_list. The selected member ports displayed are the results of the calculation using the keys for the ports in the port_list, and the list of aggregator ports for the load sharing group. This command serves as port-based load sharing calculator for convenience.
The following output shows the egress member ports selected for distribution in a load sharing group with master port 5:1, and aggregator ports 5:1 and 6:1 for packets received on ports 1:1-1:8, with default keys as shown.
# show sharing port-based keys ports 1:1-8 1:1: 0 1:2: 1 1:3: 2 1:4: 3 1:5: 4 1:6: 5 1:7: 6 1:8: 7 # show sharing distribution 5:1 port-based keys ports 1:1-8 1:1 -> 5:1 1:2 -> 6:1 1:3 -> 5:1 1:4 -> 6:1 1:5 -> 5:1 1:6 -> 6:1 1:7 -> 5:1 1:8 -> 6:1
This command was first available in ExtremeXOS 15.4.
