Configures the base URL for network login.
| url | Specifies the base URL for network login. Note: The
netlogin base-url is restricted to 79 characters.
The base URL default value is “network-access.com.”
When you login using a web browser, you are redirected to the specified base URL, which is the DNS name for the switch.
You must configure a DNS name of the type “www.xx…xx.xxx” or “xx…xx.xxx”.
This command applies only to the web-based authentication mode of network login.
The following command configures the network login base URL as access.net:
configure netlogin base-url access.net
This command was first available in ExtremeXOS 11.1.
