configure netlogin delete mac-list
configure netlogin delete mac-list [mac {mask} | default]
Description
Deletes an entry from the MAC address list for MAC-based network login.
Syntax Description
mac Specifies the MAC address to delete.
mask Specifies the number of bits to use for the mask.
default Specifies the default entry.
Default
N/A.
Usage Guidelines
Use this command to delete an entry from the MAC address list used for MAC-based network login.
Use this command to remove the default MAC-list configuration after running enable netlogin mac.
The following command deletes the MAC address 10:20:30:40:50:60 from the list:
configure netlogin delete mac-list 10:20:30:40:50:60
This command was first available in ExtremeXOS 11.1.
Platform Availability
