Unconfigures the port information portion of the circuit ID.
| port_list | Specifies the port(s) for which port information of the circuit-ID is unconfigured. |
| all | Specifies all ports. |
The default is all.
This command unconfigures the port information portion of the circuit ID string for the indicated ports thereby restoring it to the default (ifIndex value).
This command was first available in ExtremeXOS 12.3.
