Unconfigures the VLAN info portion of the circuit ID of a VLAN.
| vlan_name | Specifies the VLAN for which VLAN information of the circuit-ID is unconfigured. |
| all | Specifies all VLANs. |
| dynamic | Configuration options for dynamically created VLANs. |
The default is all.
This command unconfigures the VLAN information portion of the circuit ID of a VLAN, restoring it to the default.
Dynamic VLAN option added in ExtremeXOS 30.2.
