configure netlogin ports restart
configure netlogin ports [all | port_list] restart
Description
Enables the network login port restart feature.
Syntax Description
all Specifies all network login ports.
port_list Specifies one or more network login ports.
Default
The default setting is no-restart; the network login port restart feature is disabled.
Usage Guidelines
Use this command to enable the network login port restart feature on a network login port. This allows network login to restart specific network login-enabled ports when the last authenticated supplicant releases, regardless of the configured protocols on the port.
Configure network login port restart on ports with directly attached supplicants. If you use a hub to connect multiple supplicants, only the last unauthenticated supplicant causes the port to restart.
Enabling ONEPolicy removes the action of this command. This command is supported only in non-policy mode
To display the network login settings on the port, including the configuration for port restart, use the following command:
show netlogin port port_list
Output from this command includes the enable/disable state for network login port restart.
The following command enables network login port restart on port 1:1:
configure netlogin ports 1:1 restart
This command was first available in ExtremeXOS 11.6.
Platform Availability
