Disables the network login port restart feature.
all | Specifies all network login ports. |
port_list | Specifies one or more network login ports. |
The default setting is no-restart; the network login port restart feature is disabled.
Use this command to disable the network login port restart feature on a network login port.
Configure network login port restart on ports with directly attached supplicants. If you use a hub to connect multiple supplicants, only the last unauthenticated supplicant causes the port to restart.
Enabling ONEPolicy removes the action of this command. This command is supported only in non-policy mode
To display the network login settings on the port, including the configuration for port restart, use the following command:
show netlogin port port_listOutput from this command includes the enable/disable state for network login port restart.
The following command disables network login port restart on port 1:1:
configure netlogin ports 1:1 no-restart
This command was first available in ExtremeXOS 11.6.
