disable cli scripting {permanent}
Disables the use of the CLI scripting commands. When used without the permanent option, it disables the CLI scripting commands for the current session and is a per session setting. The permanent option affects new sessions only and is saved across switch reboots.
| permanent | Disables the CLI scripting commands for new sessions only; this setting is saved across switch reboots. |
CLI scripting commands are disabled by default.
You can disable the CLI scripting commands for the session only after this feature has been enabled.
This command was first available in ExtremeXOS 11.6.
The permanent option was added in ExtremeXOS 12.0.
