This command allows you to disable the default auto refresh behavior. The auto refresh behavior is used for some "show" commands.
| session | Use refresh setting for this CLI session only. |
| permanent | Use refresh setting for this CLI session, and all future sessions (default). |
Use this command to disable the show command auto refresh or add the no-refresh option to the individual command. Since the default for the session may be set to disable cli refresh, the commands that take a no-refresh option now allow for the alternate refresh case if you want to selectively enable a refreshed display.
The permanent option is only valid for admin level users.
The following is sample output showing the CLI refresh information.
# show management
CLI idle timeout : Enabled (20 minutes)
CLI max number of login attempts : 3
CLI max number of sessions : 8
CLI paging : Enabled (this session only)
CLI space-completion : Disabled (this session only)
CLI configuration logging : Disabled
CLI scripting : Disabled (this session only)
CLI scripting error mode : Ignore-Error (this session only)
CLI persistent mode : Persistent (this session only)
CLI prompting : Enabled (this session only)
CLI refresh : Enabled (this session only)
Telnet access : Enabled (tcp port 23 vr all)
: Access Profile : not set
SSH Access : ssh module not loaded.
Web access : Enabled (tcp port 80)
This command was first available in ExtremeXOS 16.1.
