Disables the PIM ECMP feature.
| iproute | IP Route |
| sharing | Equal Cost Multipath Routing |
Disabled.
None.
The following command disables the PIM ECMP feature:
disable pim ipv4 iproute sharing
This command was first available in ExtremeXOS 15.3.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
