disable pim snooping
disable pim snooping {{vlan} name}
Description
Disables PIM snooping and clears all the snooping PIM neighbors, joins received on the VLAN, and the forwarding entries belonging to one or all VLANs.
Syntax Description
name Specifies a VLAN.
Default
Disabled.
Usage Guidelines
None.
The following command disables PIM snooping for all VLANs on the switch:
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
