This command has been replaced with the following command: delete l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Deletes the VPLS with the specified vpls_name.
| vpls_name | Identifies the VPLS within the switch (character string). |
| all | Specifies all VPLS. |
N/A.
This command deletes the VPLS with the specified vpls_name. All PWs established to VPLS peers are terminated. The all keyword may be used to indicate that all VPLS instances are to be deleted.
This commands deletes the VPLS myvpls:
delete vpls myvpls
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
