delete vm-tracking vpp
delete vm-tracking vpp {vpp_name}
Description
Deletes the specified LVPP.
Syntax Description
vpp_name
Specifies a name for the LVPP to delete.
Default
N/A.
Usage Guidelines
None.
The following command deletes the VPP named vpp1:
# delete vm-tracking vpp vpp1
This command was first available in ExtremeXOS 12.5.
Platform Availability
