Disables network login modes.
| dot1x | Specifies 802.1X authentication. |
| mac | Specifies MAC-based authentication. |
| web-based | Specifies web-based authentication. |
All types of authentication are disabled.
Any combination of authentication types can be disabled on the same switch. To enable an authentication mode, use the following command:
enable netlogin [{dot1x} {mac} {web-based}]The following command disables MAC-based network login:
disable netlogin mac
This command was first available in ExtremeXOS 11.1.
