Enables network login authentication modes.
| dot1x | Specifies 802.1X authentication. |
| mac | Specifies MAC-based authentication. |
| web-based | Specifies web-based authentication. |
All types of authentication are disabled.
Any combination of types of authentication can be enabled on the same switch. At least one of the authentication types must be specified on the command line.
Entering enable netlogin mac adds configure netlogin add mac-list default configuration by default.
To disable an authentication mode, use the following command:
disable netlogin [{dot1x} {mac} {web-based}]The following command enables web-based network login:
enable netlogin web-based
This command was first available in ExtremeXOS 11.1.
Default configure netlogin add mac-list default configuration was added in ExtremeXOS 31.3.
