Initialize/reset the network login sessions for a specified supplicant.
| mac | Specifies the MAC address of the supplicant. |
N/A.
This command is essentially equivalent to a particular supplicant logging out. The MAC address will be cleared from the FDB, the port is put back to its original VLAN (for campus mode), and the port state is set to unauthenticated, if this was the last authenticated MAC on this port.
The following command resets the Network Login session for the supplicant with the MAC address of 00:e0:18:01:32:1f:
clear netlogin state mac-address 00:e0:18:01:32:1f
This command was first available in ExtremeXOS 11.1.
