Clears the NetLogin authentication state.
| port portlist | Clears only for the specified ports. |
| dot1x | Clears only the 802.1x authentication state. |
| mac | Clears only the MAC authentication state. |
| web-based | Clears only web-based authentication state. |
N/A
The following example clears the dot1x authentication state on port 1:
clear netlogin state agent port 1 dot1x
This command was first available in ExtremeXOS 21.1.
