Enables the configured authentication failure VLAN on the specified ports.
| all | Specifies all ports included in the authentication failure VLAN. |
| ports | Specifies one or more ports or slots and ports on which the authentication failure VLAN is enabled. |
All ports.
Use this command to enable the configured authentication failure VLAN on either the specified ports, or all ports.
