Deletes an aggregated OSPF external route.
| ip-address | Specifies an IP address. |
| ip-mask | Specifies a subnet mask. |
| ipNetmask | Specifies IP address / Netmask. |
N/A.
This command is only valid on an ASBR.
The following command deletes the aggregated AS-external route:
configure ospf ase-summary delete 175.1.0.0/16
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
